HCC202
Apr 09, 2018Star
Connection Failure on Speed Test
I did a facory reset of my system about two weeks ago and loaded the new firmware for the system which seems to be working better. I have been able to perform spped tests on the system through the Or...
Bailey12
Apr 22, 2018Initiate
Below is the response I received from Netgear. I responded it wouldve saved may of us headaches had they mass emailed the speed test could not be conducted as they shut down that service. I'm sure my feedback was very important to them.
"Please be informed that Ookla (speed test provider) had to block Orbi requests after a flood of tests from Orbi users crashed their service.
This is the reason why the said functionality is not working from Orbi units.
We are currently working with Ookla for it to be restored the soonest possible time."
An email will be sent to you to once the service is back up.
- PaulK617Apr 22, 2018StarJTG. I’m on v2.1.3.4. My Orbi also didn’t recognize the update. Had to install it manually. Yes, I read from from somewhere in the community to try to change the channel first. The Orbi is set to auto by default for the 2.4 GHz bandwidth, switched that to channel 1 and restart the modem. So far it’s good, fingers crossed! If not, the last resort is factory reset and that’s no fun.
