yuenkarwai
Sep 02, 2017Tutor
Connection Issue with Orbi RBK40 and Synology NAS ds214se
I had issues while trying to connect the Synology NAS ds214se to the Orbi network using ethernet cable, whereas I tried to login to the orbilogin.com and found out the synology NAS is unseen under th...
TheEther
Sep 02, 2017Guru
Switch the Synology back to using DHCP. Set up a DHCP reservation on the Orbi. This will provide the Synology with a stable IP address.
yuenkarwai
Sep 02, 2017Tutor
Thanks Ether, it seem to be working now!
