Zo18
May 31, 2020Aspirant
Connection issues to 2.4ghz
I am having a problem connecting my Traeger Silverton to my ORBI. The traeger says it can only connect to a 2.4ghz. Every time I try and connect my device it connects on 5ghz and it will not work. How...
- May 31, 2020
Zo18 wrote:
I am having a problem connecting my Traeger Silverton to my ORBI. The traeger says it can only connect to a 2.4ghz. Every time I try and connect my device it connects on 5ghz and it will not work. How can I change my devise to connect to a 2.4ghz?We should clear up one issue first. A device with only a 2.4G WiFi radio cannot connect to a 5G WiFi signal. That is like saying, "I bought a black and white television, but when I turn it on the programs are in color." The grill cannot connect to 5G.
Traeger mentions several times that customers may have problems with WiFi having both 2.4G and 5G:
https://www.traegergrills.com/support/wifire-troubleshooting Apparently, their app is written poorly and requires the phone to be connected at 2.4G while running the initial setup. (After that, it won't matter.)
A procedure that has worked for many Orbi owners is this:
method has worked for many people on the forum:
- Access the Orbi web interface (http://orbilogin.net) using the admin credentials user "admin" and the Orbi router password (not the WiFi password)
- Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
- Uncheck the box "Broadcast SSID on 5G Channel"
This will not affect any devices which are currently attached to the Orbi at 5G. - On the smartphone settings, "forget" the Orbi WiFi
- Search for WiFi networks and select the Orbi WiFi
- Enter the WiF password and connect
- At this point, open the IoT app and go through the steps
- After the device is connected, reverse the steps
Check the box "Broadcast SSID"
"Forget Orbi WiFi"
Search for and connect.
Please give this a try and comment on how it went.
michaelkenward
Jun 01, 2020Guru - Experienced User
Another toy to add to CrimpOn's list of poorly implemented IoT setup apps.
Please contact Traeger and alert it to the fact that the world is moving into a Mesh world and that its routine will cause grief to an ever larger set of users.
