sbevevino
Jan 11, 2020Aspirant
connection issues using Orbi and a Combo modern/wifi
okay folks. i need help. I have an Orbi RBK50 (circle with Disney) netgear router w/satellite. I also have a modem that is an xfinity model, XFsetup -BC20....it is also a wifi. I need to run 2 ...
- Jan 12, 2020
sbevevino wrote:oops. I mean the ORBI. in to AP mmode. yes I need both
You need one or the other.
Either the ISP device in modem only mode or the orbi in Access point.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
Jan 11, 2020Guru - Experienced User
If you truly need the wifi of the ISP modem/router, then put your orbi in AP mode. You're in a double nat which can cause many different types of conflicts.
sbevevino
thank you...this makes perfect sense. How do I put the router /modem in to AP mode. it is a non netgear device provided by comcast.
