janhillebrand
Sep 15, 2022Tutor
Connection issues with a single device
Hi, I recently bought the AX4200 5G router on firmware v4.6.5.11_1.5.50 and one satellite running v4.6.5.14, which should be the latest available versions respectively to my knowledge. There are ...
- Sep 15, 2022
So what model modem do you have? Is this a Orbi NBK750 series?
If you turn OFF the RBS, does the Mac Book still exhibit problems?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Sep 15, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What OSX is on the Mac Book? I use Monterey and Ventura on my Mac Book Pro 2018.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
- janhillebrandSep 15, 2022Tutor
Hi,
I appreciate your feedback. The router itself is the modem, since it is a 5G router, hence no cable necessary. I'm on MacOs Monterey 12.6. I'm not sure how the size of my apartment matters if the router is 1.5m/5 ft away from my laptop with no walls or other obstructions in between. At any rate, the satellite is about 10m/30ft away from the router. All the other devices, both those connected to the satellite and router, have very good connection speed, independently of their location. Any further ideas? Thanks.
Cheers,
Jan
- FURRYe38Sep 15, 2022Guru - Experienced User
Any Wifi Neighbors near by? If so, how many?- janhillebrandSep 16, 2022Tutor
Indeed, it's the NBK752. Today, the laptop's working again without me changing anything. Thanks for pointing me to the issue of overlapping networks. There are quite a few in the area. I'm attaching an overview. Strange, nonetheless, because my phone even when placed right next to the laptop would work just fine on wifi and I would have expected it to experience similar connectivity issues if destructive signal interference was the cause. Plus, the laptop continued having them, even when placed at a different location.
I have now changed the 5GHz to channel 48. The optimum would probably be those channels that my router doesn't support (>=52, >=112). For 2GHz is was unsure which to choose - it is on Auto. What would you recommend based on the data in the PDF attached (my network is CHill)? Why is my max. data rate lower than some of the other networks?
Thanks a bunch for your support.
