anderer
Jun 17, 2019Follower
connection issues with iMac (MacOS Mojave) and Laserjet Pro MFP
Quite often, I cannot print from my iMac to the LaserJet Pro MFP M277dw, because I get the message, that there is no connection between the iMac and the LaserJet. Both devices show a very good connec...
Fl1ntstone
Jun 17, 2019Apprentice
Hello,
It looks like the printer only works at 2.4Ghz but your iMac will work on both 2.4Ghz and 5Ghz but looks like it is being 'bandsteered' to use 5GHz. Some how you will need to force your iMac to use the 2.4Ghz band?
CheerZ
