JosueDG
Jul 21, 2020Follower
Connection issues with my Orbi RBK43S
Salutations! I recently purchased an Orbi RBK43S from Best Buy as I moved into a larger residence. Installation was a breeze and I have had no issues for the past week. However, today has been troubli...
Jul 21, 2020Guru - Experienced User
Disable the wifi radio on the laptop while the ethernet cable is plugged in.
If you have a modem gateway that has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
