jthomp30
Aug 04, 2017Follower
Connection Issues
I'm having an issue when trying to connect monitor audio airplay amps to my orbi wifi. They just don't connect. I'm also having the same problem with my logitech airplay speaker ?
1 Reply
Sort By
- DarrenMSr. NETGEAR Moderator
Hello Jhomp30
Does it give you a error or does it fail to connect? have you tried lowering the wireless channel?
DarrenM
