Sdpoorman
Feb 10, 2019Aspirant
Connection issues
I have had the Orbi system for almost 8 months with no issues. Everything worked perfectly in my 1500 sqft home. Recently I have started having issues with my the WiFi dropping off of my phone and oth...
Feb 11, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Sdpoorman wrote:
I have had the Orbi system for almost 8 months with no issues. Everything worked perfectly in my 1500 sqft home. Recently I have started having issues with my the WiFi dropping off of my phone and other devices. I can be 2 feet from the device and it will drop out, reconnect and drop again. The software is up to date and I continuously pull between 90-170mbs wirelessly. Any suggestions and to the cause? It’s starting to get really annoying.
Sdpoorman
Feb 11, 2019Aspirant
Home is about 1300sqft, wood frame. Very open. The router and the satellite are about 20 ft a part. It had been working fine and these issues just recently started.
Can I change all those settings in the app? I was looking for the options to do that and couldn’t find where to.
- FURRYe38Feb 11, 2019Guru - Experienced User
I would move the satellite a bit farther away, 20 feet is too close. 30 feet is a good starting point for placement.
To make changes you'll need a PC or latop connected to the router and use a web browser to make changes at orbilogin.com in the browser.
