Sdpoorman
Feb 10, 2019Aspirant
Connection issues
I have had the Orbi system for almost 8 months with no issues. Everything worked perfectly in my 1500 sqft home. Recently I have started having issues with my the WiFi dropping off of my phone and oth...
Sdpoorman
Feb 11, 2019Aspirant
Home is about 1300sqft, wood frame. Very open. The router and the satellite are about 20 ft a part. It had been working fine and these issues just recently started.
Can I change all those settings in the app? I was looking for the options to do that and couldn’t find where to.
Feb 11, 2019Guru - Experienced User
I would move the satellite a bit farther away, 20 feet is too close. 30 feet is a good starting point for placement.
To make changes you'll need a PC or latop connected to the router and use a web browser to make changes at orbilogin.com in the browser.
