Griffmyster's avatar
Griffmyster
Follower
Dec 12, 2019
Connection of devices
Why do wifi items closest to the satellite not connect to it?
They connect back to the router with a weaker signal, is there a way to manually Manage these connections?
Thanks in anticipation 🤔
1 Reply
  • FURRYe38's avatar
    Most devices decide on there own on which signal to connect too.
    You can reduce the power output of the RBR to help with this.
    Under Advanced Tab/Advanced Settings/Wireless Settings
    Try 75% or 50%.
