Tspeed
May 23, 2018Tutor
Connection problems RBK50 and Qualcomm Atheros QCA61x4 (Acer)
I'm running my RBK50 for about one week but having issues just with one laptop. It is my Win10 Acer with the Qualcomm Atheros QCA61x4 Chipset. If I get the laptop connected (which is not very often),...
May 23, 2018Guru - Experienced User
What FW is currently loaded on the Orbi?
What channels are you using? Auto or manual 1, 6 or 11 on2.4ghz or any channels on 5ghz?
Have you disabled Beamforming, MIMO, Daisy chain and Fast Roaming?
Is WMM enabled or disabled? Should be ENABLED.
- TspeedMay 28, 2018TutorSorry for the late reply. Here are the answers:
Orbi Router-Firmware:
V2.1.4.10Channels: Auto is set on 2.4 GHz and 36 on 5 GHz.
Daisy-Chain is enabled, everything else is disabled.
WMM is enabled.
Laptop is running currently on the Speedport Wifi without any issues.
