Nrk
Jun 04, 2019Aspirant
Connection timed out banking websites
On odd occasions I am not able to connect to these websites. ( Connection times out). https://netbanking.hdfcbank.com/netbanking/ Onlinesbi.com I have power of and power on the router twice or th...
- Jun 19, 2019Ok doesn't seem to be a problem with the Orbi ... multiple people using the same ISP are facing the problem..
Jun 04, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Only this site or do others do the same thing?
Onlinesbi.com
I have power of and power on the router twice or thrice before these sites become accessible.
I can access these sites through my mobile and through VPN.
Any thoughts
Nrk
Jun 06, 2019Aspirant
Orbi acts as a router.
Firmware Ver 2.3.1.58
The cable from ISP connects directly to Orbi there is no modem on premises.
- NrkJun 06, 2019Aspirant
These are the only sites where I have noticed the problem.
- FURRYe38Jun 07, 2019Guru - Experienced User
IF you connect directy to the ISP services with your PC, does this still happen?
Has a factory reset and setup from scratch been performed on the RBR yet?
- NrkJun 18, 2019AspirantDoesn't happen when I connect directly to the ISP.
Yes reset the router and updated firmware and reconfiged the RBR
Thanks
