Flo_Amsterdam
Jan 01, 2024Aspirant
connection troubles rbs40v satellite to rbr750 router
hi got an rbs40v from my previous setup, no I want to connect this one to my newly installed router, the rbr750. but seems hard getting them to work together. got this far, changed satellite...
CrimpOn
Jan 01, 2024Guru - Experienced User
This might be related to exactly which model of RBS40V you have. Please check the product label on the bottom of the device.
- Flo_AmsterdamJan 01, 2024Aspirant
it says
orbi voice rbs40v
- FURRYe38Jan 03, 2024Guru - Experienced User
