Aug 14, 2019Aspirant
Connection/firewall issue
I just switched to fiber. (Htc). Now I can’t log my tv on to internet through Orbi. It is logged on to orbi. There are several sites that are coming up 404 not found. Including orbi downloads. If I...
- Aug 15, 2019
Any progress on this?
412 wrote:I just switched to fiber. (Htc). Now I can’t log my tv on to internet through Orbi. It is logged on to orbi. There are several sites that are coming up 404 not found. Including orbi downloads.
If I go to the htc modem. Everything works fine. The orbi does not change even if htc modem is turned off. Htc say it is not their equipment. It is a block in the orbi. Says it’s in dmz right now.
HELP
DAN
Aug 14, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
412
Aug 15, 2019Aspirant
Worked great
Thank you
Thank you
