notimportant199
Feb 05, 2020Follower
Connections to local network not working across Orbi router and satellites
Hello Everyone, I got the RBK33 [1], which includes one orbi router and two wall-plugin satellites. [1] https://www.netgear.com/orbi/rbk33.aspx After setting it up, wifi & internet both work...
Feb 05, 2020Guru - Experienced User
Is Armor or Circle enabled on the system by chance?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
