D_0D_0
Nov 05, 2020Follower
Connections to orbi needing reconnecting when powered on
I have an Orbi related question. Whenever I use my TV to stream which is connected to Orbi network, every time it is powered on, in order to stream it needs to be reconnected to the internet. It save...
Nov 05, 2020Guru - Experienced User
Possible TV issue. The TV or PC is supposed to save any security configurations including SSID name and PWs in a profile so when the same connection is used the user should have to re-enter any PW configurations or select the wifi SSID name.
Be sure the TVs FW is updated. Check with the TV mfr as well for help and informtation regarding this.
