Birddog26
Aug 28, 2019Aspirant
Connections to Orbi vs Satelite
I am total rookie when it comes to Networking. When I look at the network map on the app, it shows a number of devices connected to the main orbi on main floor and on the satellite upstairs. I have...
Retired_Member
Aug 29, 2019
Birddog26 wrote:I want The Smart TV to have the best connection.
Just curious....does your Smart TV work? Are you able to stream movies and such? If so, why worry?
Fl1ntstone
Aug 29, 2019Apprentice
Hi,
In my experience, if you reboot your Smart TV it should try and connect to the nearest Orbi WiFi SSID on the 5Ghz band; if supported by your Smart TV?
CheerZ and goodluck :)
