Birddog26
Aug 28, 2019Aspirant
Connections to Orbi vs Satelite
I am total rookie when it comes to Networking. When I look at the network map on the app, it shows a number of devices connected to the main orbi on main floor and on the satellite upstairs. I have...
Birddog26
Aug 29, 2019Aspirant
My Smart TV does work but it is Laggy, that is why I started looking into it. Sometimes it just pauses
Birddog26
BTW - the Samrt TV is Samsung - 75" Class - LED - NU8000 Series - 2160p - Smart - 4K UHD TV with HDR
I beleive it should connect with 5.0 band and higher rate. The reason I purhcased the Orbi to begin with was so I could stream HD TV easily with good resolution
- Retired_MemberAug 29, 2019
Birddog26 wrote:BTW - the Samrt TV is Samsung - 75" Class - LED - NU8000 Series - 2160p - Smart - 4K UHD TV with HDR
Did you ever provide your firmware version? Has your network and TV ever worked well?
- Birddog26Aug 29, 2019Aspirant
The TV has worked well in the past, I really never looked to see what band it connects to. It seems every once in a while that changes. I did power cycle both the orbi and the TV. the TV is still just connecting to the 2.4 Ghz Band. I do not know where to check the Firmware version
Birddog26 wrote:The TV has worked well in the past, I really never looked to see what band it connects to. It seems every once in a while that changes. I did power cycle both the orbi and the TV. the TV is still just connecting to the 2.4 Ghz Band. I do not know where to check the Firmware version
You can see your firmware version when you login to your Orbi router on your PC.
- FURRYe38Aug 29, 2019Guru - Experienced User
Try this, Under Advanced Tab/Advanced Settings/Wireless Settings, uncheck the "enable 2.4G SSID Broadcast". Save settings and reboot the RBR and TV. See if the TV connects to the 5G frequency and streams better.
FURRYe38 wrote:Try this, Under Advanced Tab/Advanced Settings/Wireless Settings, uncheck the "enable 2.4G SSID Broadcast". Save settings and reboot the RBR and TV. See if the TV connects to the 5G frequency and streams better.
...just curious to your thought process here. IF the change is made to force the TV to 5g and it does connect and improves the TV performance, then what? What about the 2.4 side? Does the user operate the network on a single band??
