Birddog26
Aug 29, 2019Aspirant
Connections to Orbi vs Satelite
I am total rookie when it comes to Networking. When I look at the network map on the app, it shows a number of devices connected to the main orbi on main floor and on the satellite upstairs. I have...
Birddog26
The TV has worked well in the past, I really never looked to see what band it connects to. It seems every once in a while that changes. I did power cycle both the orbi and the TV. the TV is still just connecting to the 2.4 Ghz Band. I do not know where to check the Firmware version
Retired_Member
Aug 29, 2019
Birddog26 wrote:The TV has worked well in the past, I really never looked to see what band it connects to. It seems every once in a while that changes. I did power cycle both the orbi and the TV. the TV is still just connecting to the 2.4 Ghz Band. I do not know where to check the Firmware version
You can see your firmware version when you login to your Orbi router on your PC.
- Birddog26Aug 29, 2019Aspirant
Probably should have mentioned this earlier. I have my router as an access point, configured like this: https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
I am not at home so I can not check firmware version. I am writing this from work. What do I do when I check the firmware later tonight? What am I looking for ?
- Retired_MemberAug 29, 2019
Birddog26 wrote:Probably should have mentioned this earlier. I have my router as an access point, configured like this: https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
When you get logged in, look to your top right of the login page. I use Chrome and that's where I see it.
WOW....the rest of the story. Yeah, you'll need to provide more details about your entire network.
- Retired_MemberAug 30, 2019
Any progress on this?
