JEM630
Apr 04, 2019Aspirant
Connectivity Issues with wired and wifi
I recently installed a new cable modem the Netgear Nighthawk CM1150V when i upgraded my internet speed to 1Gbps and had set it up with my Orbi Wifi System RBK23 with router RBR20 and two satellites R...
Apr 04, 2019Guru - Experienced User
Has the Orbi system worked before the new modem?
Did you have a prior modem working with the Orbi system?
If the CM is new and exhibiting problems, you might want to post the CM modem forum to get help with the new modem...
- JEM630Apr 04, 2019Aspirant
Yes, the Orbi worked for a bit with the new modem (Netgear Nighthawk CM1150V) and worked completely with the previous modem (ARRIS BGW210-700). but i decided to move the new modem three times, so i had to turn the router and the modem off each time.
its just that when i turn them both back on. the Orbi does not connect to the internet. but if i hook up an ethernet cable from the CM1150V to my computer I can connect to the internet. but the ethernet onnect from the CM1150V to the Orbi, the app says the wire is connected but it just doesn't have internet connection
- FURRYe38Apr 05, 2019Guru - Experienced User
I would post here and ask about the new CM modem:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Sounds like something going on with the modem.
