soniczip
Dec 15, 2018Aspirant
Connessione cablata Amplificatore e Diffusore a sistema Orbi WiFi
Salve. E' possibile collegare con cavo un sistema WiFi Orbi [ad esempio RBK23 AC2200] con un amplificatore stereo integrato [ad esempio il mio Cmbridge CXA60] e i suoi relativi diffusori [ad esempio ...
- Dec 16, 2018
I have a SX-1050 RCVR. The best way to connect older non digital equipement to wifi anything would be to find you a RCA to WiFi or BlueTooth adapter or Transmitter.
soniczip wrote:
Hi, sorry, I used the wrong example. The stereo amplifier I would like to connect to the Orbi is an old Pioneer Sa-7300 and the speakers are directly connected to it. This would be the set-up for a second room.
The Cambridge amplifier is in the main room and it's already connected to my iMac with a m2tech hiface two interface converter.
So, the real question is "can I connect an OLD stereo amplifier to the Orbi WiFi system"?
Thank you.
ekhalil
Dec 15, 2018Master
Cambridge CXA60 is a stereo amplifier. Does it have a LAN port or wifi interface?
Do the speakers connect wirelessly to the aplifier? Do they connect using Wifi or proprietary radio? Do the speakers have LAN ports?
soniczip
Thank you.
- ekhalilDec 15, 2018Master
soniczip wrote:
.........So, the real question is "can I connect an OLD stereo amplifier to the Orbi WiFi system"?
Yes, why not? Does the aplifier has a LAN port ot wifi interface? But why would you need to connect it to Orbi, what would you get out of that?
- soniczipDec 15, 2018Aspirant
The amplifief doesn't have a LAN port or WiFi interface because it's made in the 1970s! :smileyhappy:
I want to connect it to the Orbi so that I can listen to music in the second room as well while i play it via Itunes in my iMac (first room).
- FURRYe38Dec 16, 2018Guru - Experienced User
Thank you.
