soniczip
Dec 15, 2018Aspirant
Connessione cablata Amplificatore e Diffusore a sistema Orbi WiFi
Salve. E' possibile collegare con cavo un sistema WiFi Orbi [ad esempio RBK23 AC2200] con un amplificatore stereo integrato [ad esempio il mio Cmbridge CXA60] e i suoi relativi diffusori [ad esempio ...
- Dec 16, 2018
I have a SX-1050 RCVR. The best way to connect older non digital equipement to wifi anything would be to find you a RCA to WiFi or BlueTooth adapter or Transmitter.
soniczip wrote:
Hi, sorry, I used the wrong example. The stereo amplifier I would like to connect to the Orbi is an old Pioneer Sa-7300 and the speakers are directly connected to it. This would be the set-up for a second room.
The Cambridge amplifier is in the main room and it's already connected to my iMac with a m2tech hiface two interface converter.
So, the real question is "can I connect an OLD stereo amplifier to the Orbi WiFi system"?
Thank you.
soniczip
Thank you.
Dec 16, 2018Guru - Experienced User
Thank you.
