Ragkzz
Nov 10, 2020Aspirant
Connexion problem RBK23
Hi ! I’m having an issue with my RBK23 mesh system, I am connected in Ethernet from my Satellite to my computer. Internet works on several programs like google and steam but I can’t connect to Uplay ...
- Nov 10, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Nov 10, 2020Guru - Experienced User
Does the PC work if it's wire connected behind the RBR?
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Ragkzz
Hey, I can’t wire the pc to the Router but I have the 404 error on certain websites also on my phone and pc. Actually Internet works on the computer but only on certain programs or internet pages. My Modem is the BBox3 from Proximus (Belgium)
- FURRYe38Nov 10, 2020Guru - Experienced User
What mode is your modem working in? Router or Bridged?
- RagkzzNov 10, 2020AspirantAs a router
Couple of options,
