Ragkzz
Nov 10, 2020Aspirant
Connexion problem RBK23
Hi ! I’m having an issue with my RBK23 mesh system, I am connected in Ethernet from my Satellite to my computer. Internet works on several programs like google and steam but I can’t connect to Uplay ...
- Nov 10, 2020
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Ragkzz
As a router
Nov 10, 2020Guru - Experienced User
Couple of options,
