graeallan
Oct 19, 2018Aspirant
Considering Orbi RBK50 for home use
Hi, I am looking at buying Orbi RBK50 dual unit as new home wifi with BT Infinity Broadband.
I would welcome any recent experience from the community.
Looking at the Orbi tech manual, it has many...
- Oct 20, 2018
st_shaw wrote:
graeallan wrote:
Thanks.
I have one network device that needs a static ip... Any experience of using static IP with Orbi?
G.
You can set an Address Reservation on Orbi, so Orbi's DHCP server will always assign the same IP to that device.
That answered a different question. The answer to the question posed is that Orbi has no issues with true static IPv4 addresses assigned on the devices (as opposed to reserved on the router). I have loads of devices with static addresses, and I prefer static to DHCP assigned addresses in general. Why deal with DHCP request traffic if you don't have to?
st_shaw
Oct 19, 2018Master
Orbi works great for me. I'm running in access point mode behind a more techincal router, because I need IPSEC VPN and other features Orbi doesn't offer. If your home doesn't have Ethernet wiring already built-in then Orbi is a good choice.
IPV6 is not widely deployed yet, so IPV4 is the way the majority of Orbis are being used. There are no issues with IPV4.
- graeallanOct 19, 2018Aspirant
Thanks.
G.
- st_shawOct 19, 2018Master
graeallan wrote:
Thanks.
G.
- RocketSquirrelOct 20, 2018Luminary
st_shaw wrote:
graeallan wrote:
Thanks.
G.
