MarkKoops
Jan 12, 2024Aspirant
Consistant Packet loss on orbi RBR50
Starting a post since I don't know what to do anymore, Firmware: V2.7.5.4 Router model: #rbr50 router and 2 satellite OS: windows and android (I think this is what is being asked?) environment...
Jan 12, 2024Guru - Experienced User
Does this happen with the RBS turned OFF?
- MarkKoopsJan 12, 2024Aspirant
It turns out I have a rbr50v2 this is my mistake It did not show the v2 in the ORBI settings but it says so on the back of the ORBI router.
I do not know if these are the number you want but these are the ones I could find on the modem box.
Firstly a large print number with no text: CH7465LG-ZG
secondly a S/N: DEAP202203C0
On the internet I found that the model number should be: TG2492LG
I hope that these are correct since I'm not sure.
- FURRYe38Jan 12, 2024Guru - Experienced User
That model is an Arris Gateway modem with built in router and wifi. Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode- CrimpOnJan 12, 2024Guru - Experienced User
Would like very much to reproduce this experiment with my RBR50, but unsure what tool was used to create the graph.
