Cmo1
Jun 19, 2018Apprentice
constant DoS attacxks
so since upgrading to the newest firmware I see constant dos attacks every few minutes and my connection does slow.
Attack: ACK Scan] from source: 34.230.89.123, port 9543, Tuesday, June 19, 2...
Jun 19, 2018Guru - Experienced User
That IP address belongs to Amazon:
https://whois.domaintools.com/34.230.89.123
Have you fully rebooted the router and or do a ERASE on it and set it up from scratch?
Whats the Mfr and model # of your ISP modem?
Besure none of your devices are acessing and amazon services. Disconnect ALL devices accept for 1 wired PC and check speeds and connection and the log. Graduate adding one device at a time until you notice something...
Cmo1
I have two amazon echoes recently added. I bet thats what it is.
