Cmo1
Jun 20, 2018Apprentice
constant DoS attacxks
so since upgrading to the newest firmware I see constant dos attacks every few minutes and my connection does slow.
Attack: ACK Scan] from source: 34.230.89.123, port 9543, Tuesday, June 19, 2...
Cmo1
I have two amazon echoes recently added. I bet thats what it is.
FURRYe38 wrote:
That IP address belongs to Amazon:
https://whois.domaintools.com/34.230.89.123
Have you fully rebooted the router and or do a ERASE on it and set it up from scratch?
Whats the Mfr and model # of your ISP modem?
Besure none of your devices are acessing and amazon services. Disconnect ALL devices accept for 1 wired PC and check speeds and connection and the log. Graduate adding one device at a time until you notice something...
Jun 20, 2018Guru - Experienced User
Disable or turn them off and check your stuff. :smileywink:
- Cmo1Jun 20, 2018Apprentice
[DoS Attack: TCP/UDP Chargen] from source: 92.63.193.152, port 48961, Tuesday, June 19, 2018 22:36:19
- FURRYe38Jun 20, 2018Guru - Experienced User
You can look up these addresses here to see who they belong too:
- RocketSquirrelJun 20, 2018Luminary
I think these are false alarms. When I was using Orbi as a router, I saw log entries claiming devices internal to my LAN were committing DOS attacks. Ridiculous.
