pburgh19
Aug 20, 2018Aspirant
Constant dropping (wired and wireless) with two wireless satellites and one wired
I've been having an issue with daisy-chaining not working quite right, so I decided to hardwire one of my furthest satellites back to the RBR50 base. At first, everything was good and the hardwired ...
Aug 20, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Daisy chain has to be disabled if your using wired connections between router and satellites.
pburgh19
Answers in bold
What is the Mfr and model# of the IP modem the Orbi is connected to?
Technicolor DPC3216 (from Spectrum in Maine)
~5,000
The one that is hard-wired is 140' away from the router.
Using Auto, will try manual
None
Will try that as well, thank you
- FURRYe38Aug 20, 2018Guru - Experienced User
Let us know how it goes...
- pburgh19Aug 21, 2018Aspirant
Using a different LAN port on the hardwired satellite seems to have calmed the waters. Does it matter which port you use for ethernet backhaul?
- FURRYe38Aug 21, 2018Guru - Experienced User
Really? Wow. Shouldn't matter. So what port were you using and what are you using now?
