pburgh19
Aug 20, 2018Aspirant
Constant dropping (wired and wireless) with two wireless satellites and one wired
I've been having an issue with daisy-chaining not working quite right, so I decided to hardwire one of my furthest satellites back to the RBR50 base. At first, everything was good and the hardwired ...
pburgh19
Answers in bold
What is the Mfr and model# of the IP modem the Orbi is connected to?
Technicolor DPC3216 (from Spectrum in Maine)
~5,000
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
The one that is hard-wired is 140' away from the router.
Using Auto, will try manual
None
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s). Daisy chain has to be disabled if your using wired connections between router and satellites.
Will try that as well, thank you
