pburgh19
Aug 20, 2018Aspirant
Constant dropping (wired and wireless) with two wireless satellites and one wired
I've been having an issue with daisy-chaining not working quite right, so I decided to hardwire one of my furthest satellites back to the RBR50 base. At first, everything was good and the hardwired ...
Aug 21, 2018Guru - Experienced User
I would also set up a IP address reservation for the satellite(s) ON the router. This could be an issue maybe if there is a IP address conflict with the satellite and another device...
- pburgh19Aug 21, 2018Aspirant
And that's reserved using the satellite MAC address, correct? There's no way to assign a static IP on the satellite as far as I've seen.
