qxz's avatar
qxz
Follower
May 30, 2021
Constant spikes in latency / ping from ~50ms to ~2000ms every 30 seconds on wireless.
Recently, I have noticed an issue with Orbi that has been quite annoying. While on wireless, every 30 seconds ping spikes to 1000-2000ms. This is very annoying while gaming or on certain streaming services. For context, I have one satellite placed the recommend distance from the router and have tried testing ping without the satellite. The issue persists. I have tried with all of these settings on/off: Daisy Chain, MU-MIMO, Beamforming, 20/40mhz coexistence, andm changed Wi-Fi channels. Nothing seems to work.
Wi-Fi channels are currently set on manual at 6 (2.4) and 36 (5).
Firmware on V2.6.2.104
Any help is greatly appreciated. Thanks.
  • FURRYe38's avatar
    What devices do you have connected when your checking pings? Besure to test with out any wifi devices connected accept for the one testing device?
    Do wired ping test show same results?
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
  • CrimpOn's avatar
    CrimpOn
    Can you give more information about this?  What was connected to the Orbi router?  How? (WiFi or ethernet?)
    What was the ping target?
