jasonreams
Mar 24, 2020Tutor
Constant VPN reconnecting since upgrading to firmware V2.5.1.8
I was on I think a v2.3 firmware with 1 router 1 satellite. RBS50S and RBS50R. I bought a new RBS50S and it required a firmware upgrade. At least it looked required. I did the upgrade. Connected the ...
jasonreams
Apr 03, 2020Tutor
I found the problem. At the same time of the firmware upgrade my company had a VPN issue and others saw the same problem. What a coinincidence. It has not happened since.
- CrimpOnApr 03, 2020Guru - Experienced User
Oh, my. A problem NOT caused by firmware 2.5.1.8. Thanks for sharing the resolution.
VPN is becomming ever more important in this time of "Work from Home."
Glad you found a solution.
- FURRYe38Apr 04, 2020Guru - Experienced User
Thank you for letting us know that you got it solved and it wasn't a problem caused by FW. :smileywink:
FW usually isn't a problem. Application and configuration is more likely.
Be sure to mack a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. :smileywink:
jasonreams wrote:I found the problem. At the same time of the firmware upgrade my company had a VPN issue and others saw the same problem. What a coinincidence. It has not happened since.
- Retired_MemberApr 04, 2020
FURRYe38 wrote:FW usually isn't a problem.
there you go again...blind as usual....wake up please....
