jasonreams
Mar 24, 2020Tutor
Constant VPN reconnecting since upgrading to firmware V2.5.1.8
I was on I think a v2.3 firmware with 1 router 1 satellite. RBS50S and RBS50R. I bought a new RBS50S and it required a firmware upgrade. At least it looked required. I did the upgrade. Connected the ...
jasonreams
Apr 03, 2020Tutor
I found the problem. At the same time of the firmware upgrade my company had a VPN issue and others saw the same problem. What a coinincidence. It has not happened since.
CrimpOn
Apr 03, 2020Guru - Experienced User
Oh, my. A problem NOT caused by firmware 2.5.1.8. Thanks for sharing the resolution.
VPN is becomming ever more important in this time of "Work from Home."
Glad you found a solution.
