feebthompson
Jul 15, 2020Aspirant
Constant WIFI issues with ORBI RBR50
I purchased the Orbi system as we were having issues with WIFI strength in our home and possibly too many devices connected. We have 1 satelite. I have no issues when using ethernet however when usin...
Jul 15, 2020Guru - Experienced User
