Patlite
Dec 09, 2020Follower
Constantly Disconecting- Orbi RBK33
I purchased an Orbi RBK33 about a year ago. It had worked great, until the last two weeks. It is now constantly dropping the internet, and I have to reboot the router to get it back up and running. T...
Dec 09, 2020Guru - Experienced User
What firmware do you have on it? (and the satellites)
What modem/gateway do you have it connected to?
have you tried a simple factory reset and reinstall (not from backup)? maybe an old setting is causing issues.
