frank9862
May 27, 2017Tutor
Content loading issues over WiFi for Orbi RBR50
When I first bought my Orbi in March, I had no problems with install or connecting all of our home devices to the system. Sometime in mid-may, I briefly unplugged the surge protector to which the Or...
- Jun 10, 2017
I am going to answer my own questions here.
Roku 2 Issue: I gave in and purchased a Roku Express, surmising the Roku 2 was so old I was not going to find any support on that end. New Roku Express worked like a charm.
Xbox Issue: I ended up executing a factory reset on the Xbox and that solved the connection issue. Unclear if there was any correlation to the firmware update on the Orbi side, but problem fixed regardless.
DarrenM
May 30, 2017Sr. NETGEAR Moderator
Hello Frank9862
Are the devices that are having issues connected to the satellite or the main router?
DarrenM
wchp
May 30, 2017Luminary
DarrenM,
How would one determine that?
In the 1.10.x.x firmware the connected devices no longer show what is connecting to the Router vs a Satellite.
Is there a page we can navigate to, enabling us to determine what is connecting to which? (fully qualified URL?)
If you log into the Satellite the connected devices page table doesn't load either!?
