pramodpatil
Nov 14, 2019Aspirant
Continious loss of Internet Sevice : DoS Attack: RST Scan] from source (Amazon IPs)
I seen several references to same issue. The issue started recently after upgrading router to latest version V2.3.5.30. Most/all IP addresses belongs to AWS services and Amazon. Given that most /all...
CrimpOn
Nov 15, 2019Guru - Experienced User
Thought it would be interesting to look at my logs for October and November. Orbi logged 2,719 DoS attempts, and not one of the IP's you listed has appeared in my logs. Since they are all Cloud services of one kind or another (Amazon, Facebook, etc.), this could be an indication that Orbi is falsely flagging attempts to connect with devices in your Orbi. (Or, maybe looking for "more" somethings?)
It probably would make sense to let Netgear know about these "False Positives", if that is indeed what they are. Alas, I have no idea (a) how to do that, or (b) if they would care.
I still think this is unlikely to be causing disconnects.
pramodpatil
Nov 22, 2019Aspirant
I tried full reset of the router that did not go through smoothly. After loss of long hour and :smileyangry: nothing working, feel like I should throw this in trash and get a new one but different company. Hopefully Netgear technical team take care of it sooner for others. Currently I fall back to my old router, which is atleast does not lose internet connection and keep my cisco VPN running smoothly.
Netgear
Are there any solid steps to reset router to factory default ?
Can you please share the factory default firmware ?
- FURRYe38Nov 23, 2019Guru - Experienced User
Before the drastic reset, it is often useful to learn:
- What modem is the Orbi connected to (specific brand and model)?
- Is that modem "only a modem", or is it also a router and/or WiFi system?
- How often are the disconnects? Is there a definite pattern?
To factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Power OFF the ISP modem for 30 seconds than back on. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
pramodpatil wrote:I tried full reset of the router that did not go through smoothly. After loss of long hour and :smileyangry: nothing working, feel like I should throw this in trash and get a new one but different company. Hopefully Netgear technical team take care of it sooner for others. Currently I fall back to my old router, which is atleast does not lose internet connection and keep my cisco VPN running smoothly.
Netgear
