LemonPeeler
Dec 07, 2020Aspirant
Continual screen refreshes make it hard to edit device list
Is there a way to slow down or temporarily freeze the device list in the local browser menu? The continual refreshes, about every 6 seconds, makes it difficult to read the device list. It also make...
CrimpOn
Dec 08, 2020Guru - Experienced User
LemonPeeler wrote:Is there a way to slow down or temporarily freeze the device list in the local browser menu? The continual refreshes, about every 6 seconds, makes it difficult to read the device list. It also makes it difficult to select items and make changes to the device names.
Yes, there are two ways. (a) modify the html page DEV_show_device.htm, or (b) install an alternative version of DEV_show_device.htm from SLK-Purdue which has a longer timeout and also sorts the Attached Devices page on any column.
There is a line in the web html:
//itime=setTimeout("getDevices()", 5000);
which appears to say "wait 5,000 miliseconds (5 seconds) before updating the page." The vi text editor is part of the Orbi "busybox" utilities and could be used to change the value to something larger.
I have installed Scott's Attached Devices and I LOVE it. That said, unless a person is comfortable with telnet, linux, the vi editor, and messing around in the "innerds" of Orbi software, it may not be something to mess with.
ALTERNATIVE 2:
Instead of changing device names on the Attached Devices page, go to the Advanced Tab, Security, Access Control page. Turn on Access Control (temporarily at least), then check the circle next to any device and click on "Edit". make the changes, then click "Apply". This brings up the same device name editing box as Attached Devices does.
SLK-Purdue
Dec 08, 2020Luminary
My alternative page currently works for all version 2.5.2.4 and earlier. I am currently working on a update for 2.7.1.60. I will be looking tester soon.
Scott
ALTERNATIVE 2:
