KaptenT
Aug 20, 2020Follower
Continues asking for login credentials
I have succesfully installed my ny system the other day.
Added several devices, initially it seems to work but then it start to ask for log in all the time.
Any idea, what did I do wrong?
Do I need to use the Circle app or can I just use the Orbi app?
The only thing I changed was the password during the setup.
- MstrbigMasterwhen you say login are you referring to the WIFI password or login to orbilogon.com or the app?
What modem are you connecting it to?
I've seen this issue but it tends to be with people who are in a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
What firmware is on the router and satellites?
