Zyzlt
Jul 25, 2019Aspirant
Controlling Link Rate
I have the RBR50 running firmware: V2.3.1.60 system and I am having problem with consistent link rate on my devices. The main problem I am having is the control of the Link Rate. The system is a...
Jul 25, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Link rates are auto controlled by the connected device.
What devices are you seeing these low link rates on?
- ZyzltJul 25, 2019Aspirant
Cable Modem is Arris - no problems with this i am consistantly above my 400 Mbps internet connection.
Orbi is in Router Mode.
Home is about 1200sq I have an Orbi base station upstairs and satallite down stairs. The devices that are having this problem are many and spread out around the house. Some 10 ft away with clearn line of sight of the base station.
I am currenlty using Auto and have adjusted this setting on a regular basis between Auto and individual channels for both 2.4Ghz and 5Ghz. I can see 2-4 wireless networks in range.
Breanforming and MIMO are enabled. All other option are disabled.
I have seen this isse on Apple TV 3rd gen, Apple TV 4K, Iphone Xs Max, Nexus 6, Surface Pro 2, Xbox One and X. It is normally only 1 or 2 device at a time that ever gets this. I notice it even for LAN traffice to a media server i have i wont be able to stream content from it due to slow Link Rate on one of the devices.
- BrooklynOrbiMar 06, 2020Aspirant
FURRYe38 wrote:Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Link rates are auto controlled by the connected device.
How do you access "Advanced Tab/Advanced Settings/Wireless Settings"? I don't see that option in the Orbi app and I cannot seem to find a way to manage Orbi via desktop. I just get the following instructions when I try, which are incomprehensible and don't help:
Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected:- Use the NETGEAR Orbi app
The Orbi app makes it easy to set up and manage your WiFi router. Just connect your mobile device to Orbi’s WIFI network and the app will walk you through the rest. Once set up, you can manage your connected devices, run a quick Internet speed test, pause internet, set up Circle® with Disney smart parental controls, and much more.
Check it out on the Apple App Store and Google Play Store - If you’d still like to use orbilogin.net on your computer, visit the troubleshoot page.
- Some browsers may have cached this page by accident. Follow the instructions below to clear the cache and try again:
Internet Explorer (IE):- For Internet Explorer, click on Tools > Internet options and select Delete browsing history.
- Make sure all options are checked and then click Delete.
Google Chrome:- For Chrome, go to the browser toolbar, click More Tools and select Clear Browsing Data.
- Select the “beginning of time” option and then click Clear Browsing Data.
All other browsers- Please refer to your browser’s user menu
