Zyzlt
Jul 25, 2019Aspirant
Controlling Link Rate
I have the RBR50 running firmware: V2.3.1.60 system and I am having problem with consistent link rate on my devices. The main problem I am having is the control of the Link Rate. The system is a...
Jul 25, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Link rates are auto controlled by the connected device.
What devices are you seeing these low link rates on?
BrooklynOrbi
Mar 06, 2020Aspirant
How do you access "Advanced Tab/Advanced Settings/Wireless Settings"? I don't see that option in the Orbi app and I cannot seem to find a way to manage Orbi via desktop. I just get the following instructions when I try, which are incomprehensible and don't help:
Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected:
- Use the NETGEAR Orbi app
The Orbi app makes it easy to set up and manage your WiFi router. Just connect your mobile device to Orbi’s WIFI network and the app will walk you through the rest. Once set up, you can manage your connected devices, run a quick Internet speed test, pause internet, set up Circle® with Disney smart parental controls, and much more.
Check it out on the Apple App Store and Google Play Store- If you’d still like to use orbilogin.net on your computer, visit the troubleshoot page.
- Some browsers may have cached this page by accident. Follow the instructions below to clear the cache and try again:
Internet Explorer (IE):
- For Internet Explorer, click on Tools > Internet options and select Delete browsing history.
- Make sure all options are checked and then click Delete.
Google Chrome:
- For Chrome, go to the browser toolbar, click More Tools and select Clear Browsing Data.
- Select the “beginning of time” option and then click Clear Browsing Data.
All other browsers
- Please refer to your browser’s user menu
