PolakoPC
May 05, 2021Follower
Convert RBR40 to RBS40 : stuck
Hi there
i just tried to convert my RBR40 to RBS doing all the steps succesfully, but it wont connect to the router, its not visible at all.
i really need help, im not an expert.
Thanks
1 Reply
There is no offical coverting an RBR to an RBS. Just 3rd party ways of going it.
And they put you at risk of bricking your rbr (as you've found out)
Its why it isn't officially supported and why you won't find support on here for it.
You can always try tftp or nmrpflash to recover it but you'd be better off to go to the site that you found the info on and ask for help there.
