madhatter
Aug 25, 2020Apprentice
convert RBR40 to RBS40
Does any one have the step by step instructions to convert an Orbi RBR40 to an RBS40? I've got a spare RBR40 that came as part of an RBK43 bundle hanging around and it would be more useful as a sate...
Aug 25, 2020Guru - Experienced User
Converting RBR to RBS isn't supported. You might do a search on reddit for this info on there as I had seen it on there. I would not recommend it unless you are skilled and have the experience to do this. Bricking your expensive RBR is possible.
Good Luck.
- madhatterAug 25, 2020Apprentice
yes, I know it's not supported, and the RBR is useless as it is since I am using an Orbi RBR50 as a router. I did check reddit and the instructions there were for an RBR50 > RBS50 conversion.
Thanks!
- FURRYe38Aug 25, 2020Guru - Experienced User
I can only presume it may apply to the RBR40. Again, it's a risk. Up to you.
Good Luck.
