madhatter
Sep 21, 2021Apprentice
CONVERT RBR40 TO RBS40
I followed the instructions posted on reddit and it bricked my RBR40. I'm guessing I didn't start out with the right firmware version before starting the process. The reddit posts don't mention wha...
- Sep 21, 2021
The only conversion that I recall is turning an RBR50 into an RBS50. Are you certain that the hack you employed is intended for an RBR40?
madhatter
Sep 22, 2021Apprentice
Hi, thanks, yes, here are the instructions I followed:
https://www.reddit.com/r/orbi/comments/i6qbca/success_converted_from_rbr40_to_rbs40/
CrimpOn wrote:The only conversion that I recall is turning an RBR50 into an RBS50. Are you certain that the hack you employed is intended for an RBR40?
Sep 22, 2021Guru - Experienced User
I'd stick with discussing it on the reddit forum where members have done it as well as since its not a official procedure
