Pascal2900's avatar
Pascal2900
Follower
Apr 05, 2021
Convert RBR50 to RBS50 : stuck
Hi,
I know this will not be officialy supported. But I have already converted a RBR40 to a RBS40 succesfully.
Now , i was in the process of converting an RBR50 to RBS50, and already changed the model ID via Telnet (ok)
The next step is then: reboot and login to the (former) router again, and manualy upload the fimware via the Web GUI
Except: i can not login to the standard SSID (ORbi xx) anymore?
My other RBR50 (router with some satelites) can find it as a satelite (because I renamed it with telnet commands). But of course; the semi converted RBR still has the router firmware on it.
The Netgear login web page keeps saying: configure synchronisation....but I fear it will not be able because of the wrong firmare.
I have tried FTPT client firmware upgrade: but it will not flash (i connected the RBR-S with ethernet and tried couple of times with the FTPT firmware method: but no succes)
Does anyone has THE solution to get out of this "loop"?
No RepliesBe the first to reply
