Sunray20
Dec 15, 2019Aspirant
Correct Adaptor for Orbi AC2200 (RBR40)
Hi, I hope this is not too stupid a question but my adaptors have failed on two of my three orbi routers. I bought it in the U.S. and using in the UK so a voltage issue could be the reason but this h...
Dec 15, 2019Guru - Experienced User
Adatpers here for the RBR50 v1 I have is rated at 100-240v 50/60Hz Output to 12v.3.5Amp
These should work in your region.
Something to contact NG support and ask them if there is a more specific UK version of adapter that will work.
