Retired_Member
Apr 05, 2018Correct FW
Checking my FW, here's what I see. I thought there was a newer FW ready for auto-update? Model Name Device Name Current Version Status Router RBR50 RBR50 V2.0.1.4 No new firmw...
Apr 05, 2018Guru - Experienced User
I would keep this on your scheduled review:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584/highlight/true#M26234
This seems to be the most current and up to date for Beta.
From what I know, theres nothing later than v2.1.3.4 which is most current Beta. Some saw auto updates come thru using this version only. We don't know if this was a fluke or what NG intended. Again, NG pulled the .v18 upate from the auto update services so that shouldn't be seen anymore.
- Retired_MemberApr 05, 2018
Thanks
Since I'm not experiencing any 'helmet fires' with my Orbi network, I'll just wait for the next available auto update.
- FURRYe38Apr 05, 2018Guru - Experienced User
Old saying, "if it works, don't fix it."
:smileywink:
