Superdave132
Jan 03, 2020Aspirant
Corrupted Firmware
After downloading 2.5.1.8 firmware from the RBR50 website, the router gave me a error 500 when I tried to upload the firmware to the router hte second time it . Is there a fix? Thanks
- Jan 17, 2020
There is nothing to lose by trying a different browser.
Superdave132
Jan 17, 2020Aspirant
Theres no progress bar, it just goes directly to the oh snap page
CrimpOn
Jan 17, 2020Guru - Experienced User
- Superdave132Jan 18, 2020Aspirant
Thanks Crimpon, that was the fix. I tried microsoft edge and it worked. the fix was so simple I overthought the issue.
- FURRYe38Jan 18, 2020Guru - Experienced User
Curious, which browser had you been using?
Superdave132 wrote:Thanks Crimpon, that was the fix. I tried microsoft edge and it worked. the fix was so simple I overthought the issue.
I was using Firefox or Google Chrome. I had ublock origin installed and a flash block plugin which might have caused issues. I should have used a vanilla browser or private mode with no plugins for the router update.
- TehTarikManJan 20, 2020Tutor
I had a similar issue when updating the firmware. I tried this and managed to update the firmware.
1. Reboot both the RBR and satellite unit (turn-off, wait 5 minutes before powering up and wait a few minutes before you do anything). Make sure the satellite unit is connected back to main unit.
2. Update the Satellite unit first. Once updated, check on the dashboard if it's showing the correct firmware.
3. Then update the router unit.
Cheers,
- FURRYe38Jan 20, 2020Guru - Experienced User
Ok, Yes some security plug-ins can cause problems. Have a simple browser like FireFox or Opera with out any plug-ins is best to use for FW updates.
Glad you got it working again.
Superdave132 wrote:I was using Firefox or Google Chrome. I had ublock origin installed and a flash block plugin which might have caused issues. I should have used a vanilla browser or private mode with no plugins for the router update.
- Superdave132Jan 20, 2020Aspirant
Thanks for the advice, I dont have the satellite, Just the main router.
- FURRYe38Jan 21, 2020Guru - Experienced User
:smileywink:
